Author Topic: Data Modeling - Oracle 10 g  (Read 2475 times)
jagr
« on: December 18, 2007, 08:30:34 am »
Using 7.0.817 Build 817
Hi:
I have a data modeling diagram, with tables for database oracle.
I'm design a table called SC_Tipo_Contrato, this table contains a field called ID_Contrato, this field is the primary key, is autonumber, with start value at 1 and Increment Values at 1 too.
Then, I generate DDL for this table, and EA, create the following sentences in the file:
CREATE TABLE SC_Tipo_Contrato
ID_Contrato      NUMBER NOT NULL,    -- Este campo es la llave principal de la entida tipos de contrato, es un consecutivo autoincremental
Nombre_Contrato  VARCHAR2(50)    -- Este campo tiene el nombre del tipo de contrato asociado
ALTER TABLE SC_Tipo_Contrato
ADD CONSTRAINT UQ_Tipo_Contrato_Nombre_Contr UNIQUE (Nombre_Contrato)
ALTER TABLE SC_Tipo_Contrato ADD CONSTRAINT PK_Tipo_Contrato
PRIMARY KEY (ID_Contrato)
CREATE SEQUENCE SC_Tipo_Contra_ID_Contrato_SEQ
INCREMENT BY 1
START WITH 1
NOMAXVALUE
MINVALUE 1
NOCYCLE
NOCACHE
NOORDER;
CREATE OR REPLACE TRIGGER SET_SC_Tipo_Contra_ID_Contrato
BEFORE INSERT
ON SC_Tipo_ContraFOR EACH ROW
BEGIN
 SELECT SC_Tipo_Contra_ID_Contrato_SEQ.NEXTVAL
 INTO :NEW.ID_Contrato
 FROM DUAL;
END;
Look at the sentence in the red color, you can see the error, the table name is truncate.
I don't know if exist another solution different to change the table name and cut this name.
I have another question ¿how can i do to define the tablespaces in oracle for the primary key's index?
Thanks for your help
