Author Topic: Another picture as Actor  (Read 4102 times)
dchrist1
« on: December 20, 2007, 02:00:57 am »
how can I use an actor with another picture like this one:
best regards
dchrist1
Re: Another picture as Actor
« Reply #1 on: December 20, 2007, 04:58:13 am »
Import the image into EA - you'll find directions in EA help.
Create a stereotype for actors that should use this image in the Stereotypes tab of the Settings | UML dialog.
Assign your image to the stereotype on the same dialog.
Stereotype any actors that should use this image.
If you still get the 'stick man' shape, try toggling the Use Rectangle Notation setting on the context menu (I think that setting is under Advanced in the menu).
If that doesn't work, please get back to us.
« Reply #2 on: December 20, 2007, 12:54:56 pm »
After importing an image into your model you can also assign it as an alternate image without setting up a stereotype.
Right click on the actor in the diagram and select Appearance | Select Alternate Image.
« Last Edit: December 20, 2007, 12:55:14 pm by simonm »
« Reply #3 on: December 20, 2007, 01:24:03 pm »
Thanks Simon,
That sounds like a much cleaner solution in this case.
« Reply #4 on: December 21, 2007, 02:24:09 am »
dchrist1,
Is you customer support really working with machines from the last millenium? Hey, it's Christmas time. Go and buy them some fancy new ones ;D
