Author Topic: WAN Performance/Best Practices  (Read 11124 times)
Martin Terreni
  • Sorry, I can't write
Re: WAN Performance/Best Practices
« Reply #15 on: December 23, 2007, 03:19:13 am »
Hi jdrake4,
Does Oracle come with some sort of database replication technology?
We found the same problem with EA performance but it is solvable using MS SQL Server with merge replication between database instances.  We have been using EA on 2 replicated databases succesfully for the last month.
There is a bug with EA which Sparx fixed in the latest build (copy and paste diagrams was broken on a replicated SQL Server EA database).
If you switch to SQL Server - I can give you the replication scripts you need to set this up plus an amended base SQL script to create the EA tables correctly for replication.
Cheers,
David.
Could you mail them to me too?THANKS!
Recursion definition:
« Reply #16 on: December 23, 2007, 03:40:54 am »
Hi Dave,
Could you please also send me the new version? I've made major changes to my SQL Server version - which seem to have improved most non-EA things a lot - since you last sent your scripts out. I think it's time I updated.
And yes, I'm running the current EA build.
Martin Terreni
« Reply #17 on: December 23, 2007, 01:11:01 pm »
It seems also Sparx is having some trouble... ;D
