Author Topic: Column order in the schema diagram  (Read 3428 times)
ravindar_ragavan
« on: January 03, 2008, 10:59:44 am »
I created a schema model with set of tables. The problem is that in schema diagram the columns of the tables are ordered by column name. But I want to see the order in which I defined the column for the table.So how to do this?
Re: Column order in the schema diagram
« Reply #1 on: January 03, 2008, 11:37:00 am »
On the Tools | Options | Objects dialog, take a look at the settings at the bottom of both columns of check boxes. In particular make sure you have cleared the Sort features alphabetically box. You might also want to take a look at the Group <x> by Stereotype settings near the bottom of the right column. These won't affect your column names, but might come in handy elsewhere in your model. Play around with them.
HTH, David
ravindar_ragavan
« Reply #2 on: January 03, 2008, 01:02:15 pm »
HTH, David
Thanks David it worked.
