Author Topic: Class using STL containers modelling  (Read 3025 times)
J.B.
« on: January 24, 2008, 07:01:24 pm »
I am having trouble to create a class diagram that can generate the following similar code:
class CMyClass : list<string>
public:
CMyClass();
virtual ~CMyClass();
vector<string> m_MyTable;
Any help would be very much appreciated.
Thanks!
Re: Class using STL containers modelling
« Reply #1 on: January 24, 2008, 08:07:01 pm »
Reverse engineering the exact code is usually a good place to start...
See what EA does with it (on the way in, so to speak).
Then forward engineer what EA just created and see what comes out...
That should give you the "envelope" you need to play with...
