Author Topic: Making an element positioned 'vertically'...?  (Read 3441 times)
Martinigue
  • BlackBerry is a lifestyle
« on: January 25, 2008, 02:03:56 am »
in EA 6.5.798, in a copmponent diagram, how can I make a component element positioned vertically, instead of its standard, left-to-right placement? Is this possible?
Martin Terreni
  • Sorry, I can't write
Re: Making an element positioned 'vertically'...?
« Reply #1 on: January 25, 2008, 04:48:59 am »
You mean the lay out of elements (which you do through diagram details) or the actual image of the element (I guess you would need some scripting for this...)?
Recursion definition:
Martinigue
« Reply #2 on: January 25, 2008, 05:09:43 am »
I am talking about the actual image (if I got you right), that is - making a class element's rectangle go from down up, together with its text label of course...or maybe positioning the text label like so would be enough..
« Reply #3 on: January 25, 2008, 04:35:36 pm »
You can't rotate any elements, only labels.
rabra
« Reply #4 on: January 28, 2008, 02:06:45 am »
What about creating a stereotype (with shape script or by including an .emf - picture)?
« Reply #5 on: January 28, 2008, 06:03:20 am »
Should work, but AFAIR it does only work for stereotyped elements....
