Author Topic: unable - Generate Sequence diagrams from a .NET UI  (Read 3171 times)
vijayvrr_2001
« on: February 06, 2008, 05:31:05 am »
Hi all, I hope this is the correct forum to post this else please let me know where this needs to be moved.
I wrote a very simple hello world C#-.NET based GUI program. All that the UI (C# UI) is a message box clicking on which it should message "Hello world".
Now I need to generate a Sequence diaram of what happens on "Hello Click". For that I went ahead and configured all the debugging settings.
I can see that I can BUILD / TEST the application without error. I also set the values for the debugger. Now the issue is, I am unable to add a "Debugging bench" OR generate a sequence diagram. It does not even OPEN the UI for me to be able to button click.
Any clues?
mrf
Re: unable - Generate Sequence diagrams from a .NE
« Reply #1 on: February 06, 2008, 07:21:27 pm »
Hello. Are you running Windows Vista? We are currently resolving a Debug Workbench bug where .NET applications aren't able to be run due to a modified security model in Vista (with User Account Control turned on).
Please see the post http://www.sparxsystems.com/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1201174353 for more details.
Best Regards,
Michael
vijayvrr_2001
« Reply #2 on: February 06, 2008, 07:57:54 pm »
Hello Michael,
Thanks for the quick reply. I got the issue resolved just some time back. I am not running a vista, it is a XP machine. The error was more with the way I was configuring the CSC compiler.
Thanks anyways for the very prompt response.
VJ
