Author Topic: Symbol for composite element in stereotypes  (Read 5932 times)
balutoo
« on: February 05, 2008, 06:52:28 am »
hallo
in some elements one can see a symbol to show that the element has got a composite element.
If this element has got a stereotype this symbol is not shown any more.
Is there a possibility of showing such a symbol automatically in a stereotype with composite element??
balutoo
Re: Symbol for composite element in stereotypes
« Reply #1 on: February 05, 2008, 02:03:16 pm »
The only reason that I can think a stereotyped element wouldn't show the composite element indicator is if the stereotype applies a shape script. You can modify the shape script to show a composite symbol of your own design, something like this:
decoration composite
 orientation="se";
 if(hasproperty("iscomposite","true"))
   // draw your own glyph here...
If there is some other reason why you aren't seeing the link symbol, you'll need to give some more details (i.e. tell us which element and stereotype).
balutoo
« Reply #2 on: February 05, 2008, 11:20:42 pm »
hallo
I tried this following code:
shape main
  noshadow = "true";
  h_align = "center";
  v_align = "bottom";
  startpath();
  roundrect(0,0,100,100, 20,20);
  moveto(05,20);
  lineto(50,10);
  lineto(95, 20);
  moveto(05,23);
  lineto(50,13);
  lineto(95, 23);
  endpath();
  setfillcolor(233,255,255);
  fillandstrokepath();
     orientation="se";
       ellipse(75, 80, 80, 85);
       ellipse(80, 80, 85, 85);
  println("#NAME#");
But there nothing happened.
I take the ACTIVITY-element in an ACTIVITY DIAGRAM in EA Version 7, build 816.
do you need any more information??
thanks for help.
« Last Edit: February 05, 2008, 11:24:59 pm by balutoo »
« Reply #3 on: February 06, 2008, 01:53:51 pm »
The decoration section needs to be a top level one, not a sub-shape of the shape main section.
rabra
« Reply #4 on: February 07, 2008, 05:32:19 am »
Hallo,
this topic is interesting for me too, and I have tried some things without success.
But I think there are some things not yet clear to me:
 orientation="se";
Is the first line of the code something like a subshape?
I call a subshape with the method 'addsubshape(subshapeName, position1, position2). Do I call this thing equivalently? Or with another call?
Or - as you write that the decoration needs to be a top level section - do I have to write directly into the shape main? (What I have tried without success)
Or do I have to replace shape main with decoration composite?
And am I right that the thing 'hasproperty("iscomposite","true")' refers to the option 'Composite Element' in an element?
« Reply #5 on: February 07, 2008, 07:06:29 am »
IIRC you just write the decoration as if it were another shape. It is at the same level as the shape main, not inside it. The script should draw both your shape and your decoration.
I think you can also decorate a 'normal' shape. If EA does not see a shape main, it will use the default rendering, adding your decoration and placing it appropriately.
balutoo
« Reply #6 on: February 08, 2008, 04:12:03 am »
Hallo
I tried out some things with shapes. If one writes two shapes one behind the other, then you can see only one. With one testscript I found out that the shape standing above is the one that is shown.
decoration eins
   startpath();
   rectangle(5, 5, 95, 95);
   endpath();
decoration zwei
   startpath();
   rectangle(30, 30, 70, 70);
   endpath();
How can I show both??
« Reply #7 on: February 08, 2008, 04:14:03 am »
Only one should be a decoration. The other should be a 'main' shape. This way the main shape will be drawn, then the decoration will be drawn on top (i.e. higher in the z-order).
Did it work?
rabra
« Reply #8 on: February 08, 2008, 04:33:40 am »
I tried out the given script from balutoo - first original, then with calling one or both parts with 'shape' instead of 'decoration', and calling one of them 'shape main'. But I always only see the shape that is first in the script.
What else may be wrong?
I think I have the same surroundings as balutoo (EA 7.816, Activity Diagram).
« Reply #9 on: February 10, 2008, 08:09:42 pm »
decoration eins
    startpath();
    endpath();
decoration zwei
    startpath();
    endpath();
You can show them in different positions, as defined by the "orientation" setting. For example:
decoration eins
   orientation="NW";  // North-West
   startpath();
   endpath();
decoration zwei
   orientation="SE";  // South-East
   startpath();
   endpath();
