Author Topic: MDG Integration 2005 "Import and Link VS projects"  (Read 3826 times)
BKV
« on: February 20, 2008, 11:24:40 pm »
I am using MDG Integration for VS 2005.
I am trying to "Import and Link VS projects" using EA Project explorer
window inside VS 2005.
There is a command in the menu:  Current Package -> "Import and Link VS projects".
The problem is that the list of available VS projects to import and connect, contains not all projects from the solution.
What is interesting, when I trying to connect to VS project from EA environment (Addin->Connect External project ->VS), than I could see all  projects.
What could be a problem?
Re: MDG Integration 2005 "Import and Link VS proje
« Reply #1 on: February 21, 2008, 12:07:00 am »
Try doing a rebuild. You may have to fiddle with the sequence of things you do a bit, but I think this works out when you get it right.
You may have to reload the EA project too, but I cannot remember. Be careful experimenting with this, so you don't accidentally reverse engineer back to a previous version.
