Author Topic: Option meaning  (Read 4528 times)
enjoySparx
  • ...We Should be pleased that if you would...
Option meaning
« on: March 03, 2008, 09:47:34 pm »
Hi All,
do you know if is there a manual explainig the meaning of each option inside the context area generated by RTF generator???
For example, between diagram> ... diagram<...
Thanks in advance...
Oliver F.
    • Karl Storz homepage
Re: Option meaning
« Reply #1 on: March 03, 2008, 10:00:05 pm »
Hi All,
You mean besides that one here:
http://www.sparxsystems.com/downloads/whitepapers/Working_with_the_RTF_generator.pdf ?
Not that I know of.
Oliver
enjoySparx
Re: Option meaning
« Reply #2 on: March 03, 2008, 10:10:47 pm »
I read deeply "working with rtf.." and i went fast using rtf generator... but unfortunatly this document did not explain a lot of little details!!! For example for each tag the list and the meaning of each related option...
Oliver F.
Re: Option meaning
« Reply #3 on: March 03, 2008, 11:14:46 pm »
I am not sure whether I can see your issue because I found them pretty self explanatory.
Can you give a few examples so we can try to elaborate the meaning ?
Oliver
enjoySparx
Re: Option meaning (intuition is not an answer)
« Reply #4 on: March 03, 2008, 11:51:19 pm »
In my opinion, there should be a section (paragraph or something else...) in document "working with rtf..." explaining for each bracketed Section  the option generated with a mouse right-click. Foe example, if i made a right-click between a section source>element> ... <element<source i obtain following choices ...Abstract, Alias, Author, ...,Type, Version, valueOf. Which is the meaning of non intuitive options (for me)??? Where can i find a little practical example for each one??? Thanks a lot!!! By
Oliver F.
« Reply #5 on: March 04, 2008, 12:55:40 am »
Most of the attributes are the 1:1 representations of their corresponding counterparts in the elements properties dialog.
As to your examples, Author is the author, Alias the alias, Abstract returns true if the element is an abstract element, Type is ... well guess what..., the same applies to Version and valueOf is the specific value of a tagged value.
So it is always worth considering the properties dialog of the element for which documentation has to be generated.
Oliver
Re: Option meaning
« Reply #6 on: March 04, 2008, 01:36:57 am »
Try exporting a (small) package to XMI. Now read through the output and you will see most of the things you see in the RTF stuff. The actual name and format might differ slightly, but you'll quickly get the idea.
I know this is a far cry from documentation, but at least it should get you moving forward. And even if you can get Sparx to document the RTF engine, it could be a long wait.
HTH, David
