Author Topic: Model change notice  (Read 17971 times)
OldEm
  • EA newbie
Model change notice
« on: February 13, 2008, 05:00:33 am »
I'm on my 28th day of trial and at yesterday's team meeting the project managers asked, "If I add a Use case or change the scenario for already built code, how do my designers/programmers know that I just made a change and that they have to modify their code?" Anyone have a change notice process that works for their team?
Re: Model change notice
« Reply #1 on: February 13, 2008, 05:21:39 am »
EA has a mighty build-in model compare feature (which has even been improved with 7.1 but I could not test that).  Search the help file for "baseline".
« Reply #2 on: February 13, 2008, 01:52:26 pm »
Another idea (maybe used in conjunction with Thomas's): Search the help for "red triangle"...
« Last Edit: February 13, 2008, 01:55:23 pm by KP »
OldEm
  • EA newbie
« Reply #3 on: February 13, 2008, 07:02:55 pm »
We use winmerge to compare code files so Baselines and compare sounds like a good method as described in the manual.
I created a baseline package, changed some of the elements, went into manage baselines, clicked show differences - and Ea crashes.
Tried this a few times with a eap file project and with my database respository project. crash each time. bummer.
I'm off to look for red triangles...
« Reply #4 on: February 13, 2008, 08:07:28 pm »
Which build were you using when EA crashed?
« Reply #5 on: February 14, 2008, 12:51:05 am »
Obviously the latest (trial).
« Reply #6 on: February 14, 2008, 06:04:51 am »
Then a retest with 7.1 would be in order; the most recent trial would appear to be version 7.0.
Jan ´Bary´ Glas
  • Bary
« Reply #7 on: February 14, 2008, 06:57:27 am »
My best practice is to set Phase globaly for new elements in any iteration of our development process and set Version the same. When we do a change, we change the version to current Phase.
That means, if you want to filter all elements changed and added in last phase, just use current phase as a version parameter.
Is it helpful and understandable?
Jan 'Bary' Glas
OldEm
  • EA newbie
« Reply #8 on: February 14, 2008, 07:29:58 am »
How can I get 7.1?
But "Compare baselines" should work in 7.0 build 818 without crashing EA.
OldEm
  • EA newbie
« Reply #9 on: February 14, 2008, 07:42:05 am »
My best practice is to set Phase globaly for new elements...
How do you set the phase globally?
This sounds like a good method for new elements. When I presented the use of EA to the team, managers asked if they could use those Phase and version fields to manage change communication to developers. I had to say I didn't know.
Here's a scenario: A Use case scenario is added in phase 1.1  and version is set to 1.1 for UC and realization model.
Later, the manager updates this UC to phase 1.2 with two new alternate paths. (not a new element) Clearly the designer/programmer can find the 1.2 version of the UC but how do they compare it to 1.1 to see that what was added was the 2 alternate paths?
(I think the answer is compare baselines using 7.1 beta release...)
« Reply #10 on: February 14, 2008, 07:48:02 am »
Yes, 7.1 is only available in beta.
Due to the way that EA releases come out, 818 will be the final build of 7.0. The current beta version of 7.1 is 825.
The reason there is no trial version of 7.1 is that beta versions are only available to registered users. When 7.1 reaches production a new trial version will be released - assuming that the usual pattern is followed.
So for now, someone else will have to retest the issue on the beta if you are still using a trial version.
Cavan “Kevin” G. Watson
  • I love EVERYTHING including Microsoft
« Reply #11 on: February 14, 2008, 09:50:47 am »
That's so mean... as if the current user base is going to want static code visualization or deep runtime insight.
It would be extremely helpfull to have access to early VS2k8 MDG Technologies, particularly if EA is to remain my preferred UML tool recommendation.
Guess I should just retire,
Kevin xxx
OldEm
  • EA newbie
« Reply #12 on: February 14, 2008, 10:56:25 am »
The EA crash on compare occurred with the corporate version.
When I select professional version (I'm still using the trial) I can compare the current model with an XMI file. No crash! The comparison summary in the elements tree and detail listing on the right is sweet - for me only.
Even if the 'baseline compare' worked in the corporate version - how is the baseline shared by the team?! If a manager saves a baseline and then changes the use cases and requirements for the next iteration, how do I as the designer/programmer see the manager's baselines? They're saved to a directory on the manager's personal computer.
I'm feeling like it's just way too hard to use this tool in a team framework.
« Reply #13 on: February 15, 2008, 12:12:46 am »
I guess it's hard with all tools. Usually you find way to accommodate with the tool. One way is to set triggers in the database that monitor changes (I faintly remember a discussion on this in the past).
Jan ´Bary´ Glas
  • Bary
« Reply #14 on: February 20, 2008, 02:28:22 am »
I thought baselines were saved in the repository (Corporate ed. only) reachable for everyone. Weren't they?
Jan 'Bary' Glas
