Author Topic: SQL Search - how to include search term in query?  (Read 7218 times)
Dave_Bullet
« on: March 13, 2008, 01:39:05 pm »
Any ideas?  or am I just not reading the help properly.
For example, I want to return the types and number of diagrams that have the search term in their name as follows:
select t_diagram.diagram_type, count(*)
from t_diagram
where name like '<search_term>'
group by t_diagram.diagram_type
Questions are:
1. Can I include the users search term in the query?
2. What syntax does EA expect so it can substitute the search term?
Cheers,
David.
Re: SQL Search - how to include search term in que
« Reply #1 on: March 13, 2008, 09:54:13 pm »
What exactly do you mean?
I've recently plugged one of these into an automation project, and it worked like a charm. I just treated it as plain old SQL - and didn't make any assumptions about syntax; nothing even remotely fancy - and it seemed to work right out of the box.
Are you trying to set this up as something in the UI. Sort of 'click and go?'
Dave_Bullet
« Reply #2 on: March 14, 2008, 06:51:13 am »
Hi David,
I'm using the native EA search facility.  3 options - query builder, SQL editor or add-in.
For the SQL editor - you get a dialogue in EA where you can paste in a SQL statement.  That's great and I can put in something like
select * from t_object.
My question is - Does the EA UI apply your search term "after" the result set is retured the client and filters the resut set on any column where the term is contained:
or
can you specify the search term within your query. ie:
select * from t_object where name = :search_term
or similar.
If I do
The search term never seems to be applied to the results, ie. whatever I type in the search term when I run the query just dumps the whole of the t_object table to the search window unfilterred.
Hope that makes sense.
The same issue would apply to an add-in search method.... how do you pass in the user entered search term to the add-in method call?  What syntax do you use?
Cheers,
David.
« Reply #3 on: March 14, 2008, 08:29:28 am »
I'll answer the last question now; I've not thought the first part out yet.
I just construct a string, which I can do at run-time, since my user needs to pick something from a list, which I use to filter. [Sometimes it is a package, other times a diagram.] The string is a normal SQL command. Something like:
Dim foo as String = "SELECT * FROM t_object WHERE Package_ID = '" & MyPackage.Package_ID.ToString & "'"
I then use this as the parameter to Repository.SQLQuery. I load the resulting string into an XML document and I'm all set.
I find this much less of a bother than trying to use RunModelSearch.
HTH, David
« Reply #4 on: March 14, 2008, 10:36:42 am »
The search term can be directly substituted in your search sql for the string '<Search Term>' (without quotes).
Dave_Bullet
« Reply #5 on: March 14, 2008, 02:02:10 pm »
Thanks Simon - that's exactly what I wanted.  Suggest Roy etc.. add this to the help (I couldn't find it).
Thanks again - (tell your boss to give you a bonus)
David.
RoyC
  • Read The Help!
« Reply #6 on: March 14, 2008, 03:07:13 pm »
I have changed the initial example SQL statement in Create Search Definitions to:
SELECT * FROM t_object WHERE NAME='<Search Term>'
Not sure if Simon meant that the quotes were not needed for the actual substituted search term, but they are need in the above statement.
Can I have a bonus too?
Best Regards, Roy
« Reply #7 on: March 14, 2008, 03:44:33 pm »
To clarify what I said,
If you ran a search with the following sql and the search term Bah
SELECT * FROM t_object WHERE NAME='Foo<Search Term>'
The actual sql that will be executed is
SELECT * FROM t_object WHERE NAME='FooBah'
