Author Topic: Aggregation Modelling  (Read 4899 times)
Cosmo Nova
« on: March 17, 2008, 02:32:56 pm »
Hi all, I was trying to draw a class diagram, where a class owns some other classes... and thus I applied the aggregation relations. I got TWO questions about this aggregation:
1. When I generated code from the class diagram, it created a poiner as member variable in the owner class. I got the same result no matter it's an aggregation or composition. How can I differentiate them in code generation?
2. When I use reverse engineering to generate class diagram, from the code just generated, I got a different diagram... The main problem is I lost ALL the aggregation relations, and they becomes normal "association" between the two classes.. The code reverse engineering supposed to be very useful when I modified the code and update the diagram through the code. How can I preserve the aggregation relations through settings or whatever?
EA is a great tool! Thanks a lot!
Re: Aggregation Modelling
« Reply #1 on: March 17, 2008, 10:25:28 pm »
Hey Cosmo,
There was some very good information on EA's implementation of these relationships quite a while back. The threads in question were started - I think - by Paolo Cantoni (in one of his incarnations, you'll have to look him up).
One point was that aggregation and composition relationships worked a bit differently depending on how you created them. This appeared to be a throwback to the UML 1.x days of EA. [I do not know if or to what extent this has been addressed. It might not be your problem here. So read on...]
Meanwhile, I have not done this for a while so I might not remember, try setting the Containment property of each end of the aggregation. You'll find this on the Target - and Source, but this is less likely to matter - Role tab of the Aggregation Properties dialog. [You can also set these through the API, and (I think) a script.]
If that does not work right away, grab a piece of your own source code - something you did not build with EA - and reverse engineer it into an EA project. Take a look at what properties EA sets, and to which values.
Any luck?
HTH, David
jeshaw2
« Reply #2 on: March 18, 2008, 02:39:44 pm »
Cosmo
You might also look at the navigation direction on the association.  Reversing what you see might help.
Cosmo Nova
« Reply #3 on: March 18, 2008, 03:06:32 pm »
Hey Cosmo,
Any luck?
HTH, David
thx ur reply
I found this thread, but is it what u were trying to quot??
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1203597016/8#8
for the Containment property, what exactly it represents in a class modelling?  :-/
« Reply #4 on: March 18, 2008, 10:02:01 pm »
Cosmo,
That's who I was referring to, but not the particular post.
Try Jim's idea first; it's quick and might do the trick.
If not, just play with containment a bit. If it does not solve your problem then you can leave the definition until later.
If you're still having problems, try importing some code that already does what you want, as I suggested above. Examine how EA models the result, and then try creating a model that is similar. Generate the code and see if that's what you wanted.
« Reply #5 on: March 19, 2008, 08:27:39 am »
EA doesn't generate anything different for compositions or aggregations.  The pointer is because of the containment specified.
The reverse engineering sounds odd, but I don't really have enough information to know what you're talking about.
