Author Topic: Version 3.10 - Build 475 released  (Read 50278 times)
sparks
« on: March 18, 2002, 02:53:06 am »
Changes and Fixes for Build 475
-VB.Net now supports Inner Classes
-Added support for Delphi properties. These are stored as tagged values and can be displayed using the Set Feature Visibility function to show Tag Compartment
-Added Delphi 'Property editor' ... can be activated from right click menu of class that has Delphi as its language
-Generate Property function amended for Delphi to provide support for custom Delphi properties
-Delphi parser now handles multiple classes in same file
-Delphi parser/generator now handles Interfaces
-Fixed bug in RTF language adjust that caused error if replacment string had ' or "  character embedded
-Fixed bug that was causing some elements to display wrapped text incorrectly
-Changed the icon displayed by diagram hyperlink to differentiate from file/web hyperlink
-Fixed bug that executed diagram hyperlink when Properties menu option selected
-Use case and Collaboration elements now support custom stereotype Metafiles
-System and Maintenance docked toolbars now support sorting of list contents on any colum
-C++ classes which include 'Friend' statement now import OK
-Added 'Parameters' input text box to Message dialog. Add parameter names here when constructing sequence and collaboration messages
-Increased length of fields for StateFlow Event, Guard and Action information
-Increased length of message name field in Message dialog
-List of names in drop downs for Project Issues, Maintenance and Task lists amended to include union of Authors and Resources
-When reloading a diagram (after class synch or association changes etc) the current scroll position is retained rather than reverting to (0,0)
-When using the ShowUsage dialog and opening a new diagram - the current object of interest is selected and highlighted in the view window
« Last Edit: March 18, 2002, 02:55:31 am by sparks »
