Author Topic: Requirement Inheritance for External Requirements  (Read 4153 times)
MichaelY
« on: March 27, 2008, 06:29:33 am »
I have approximately 1500 requirements that I loaded into EA as external requirements, some of which I need to move to Internal requirements under classes (or packages) that have been arranged in a hiearchy.  I don't see a mechanism to move requirements from External to Internal and I don't want to reload the requirements as they already have a TON of relationships established with other elements.
Anyone have some ideas on the best approach, as my understanding is that inheritence for requirements only works with internal requirements - argh... :-/
Thanks for any guidance on this...
thomas.kilian
Re: Requirement Inheritance for External Requireme
« Reply #1 on: March 27, 2008, 08:31:34 am »
With that amount you should dig the automation interface. Probably a SQL could do the same job, but then "you need to know what you're doing".
MichaelY
« Reply #2 on: March 27, 2008, 10:15:17 am »
Ya, I took a look at the database directly at first and then realized there were quite a few gaps in database relationships - ugh.
I then took a peak at the automation interface and realized that might be a long-term path for approach, but right now I need to finish modeling as much as possible by this weekend for presenting... (No time right now to learn the Automation interface) ...
However, if you know a fair amount about it, my main end concern after getting the relationships and inheritence correctly established is to do reporting beyond the RTF's capabilities (one example is creating a report for each 80+ components that Lists first the component name, description, but also then related actors, objects)
