Author Topic: Question about Repository.refreshModelView  (Read 3915 times)
damien
« on: May 29, 2008, 05:18:42 pm »
I have a question about the method refreshModelView in the repository object. I use this method after i have deleted a package in an another package to refresh the Project Browser. This method take as parameter the id of the package to reload only this package. But the entire model is reloaded.
The help say :
Reloads a package or the entire model, updating the user interface.
Parameters:
ยท PackageID: Long - the ID of the package to reload: if 0, the entire model is reloaded; if a valid package ID, only that package is reloaded
I suppose my id isn't valid but i check it and i think, it is the good id.
Perhaps the id isn't the package.packageID because the packageID is an integer and the parameter is a long
Someone can explain me, what is the parameter to give to this method ?
Thanks you
Bye
thomas.kilian
Re: Question about Repository.refreshModelView
« Reply #1 on: May 29, 2008, 06:26:25 pm »
How do you know that the whole model is reloaded? I use this method also in rare circumstances but I would not care if the whole model is reloaded, though. However, if you can prove this you should report a bug.
damien
« Reply #2 on: May 29, 2008, 06:47:47 pm »
When i use it the project closes, i return on the home page of EA and the project reopens. When the project closes, all diagrams ask to be saved.
thomas.kilian
« Reply #3 on: May 29, 2008, 07:54:06 pm »
You're probably right. I never was concerned about that so much (due to rare use) but definitely this looks like a bug. Please report it via the Register Users Bug Report form.
damien
« Reply #4 on: May 30, 2008, 08:21:32 pm »
I don't think it is a bug, i think the parameter isn't the PackageID maybe PackageGUID or something else...
