Author Topic: Use of "Diagram Gate"  (Read 6005 times)
spxea
« on: April 17, 2008, 06:53:48 pm »
I use EA 7.1.827.
- here :  http://www.sparxsystems.com.au/EAUserGuide/index.html?diagramgate.htm
we can see a gate on the boundary of a "Ref" fragment. It is mentioned that In and Out Gates are supported.
-here :
http://www.sparxsystems.com/resources/uml2_tutorial/uml2_sequencediagram.html
it is mentioned that there is no Gate on the boundary of a Ref fragment. And both Incoming/Outgoing messages are possible.
- in pratice : when I try to create Gates in a diagram, I do not find the way to indicate that a Gate is an Out Gate, neither an In Gate. Anyway, I can create both Gates with local incoming/outgoing interactions.
And when I reference this diagram from within another diagram (via a Ref fragment), no Gate is displayed (so it seems to confirm the tutorial). But at the same time, when I setup an incoming interaction to this Ref fragment, no message is displayed in the Message comboBox (in the "Message Properties" dialog), whereas I should (at least) find the messages linked to the Gates present in the referenced diagram (and if in/out Gates were differentiated, I should even get a differentiated messages list depending on an incoming/outgoing interaction), should not I?
So is it a normal behaviour? Is there something else to do to get this kind of behaviour?
Thanks.
