Author Topic: Hide connectors  (Read 3531 times)
damien
Hide connectors
« on: June 02, 2008, 07:57:25 pm »
I would hide connectors between two elements in all diagrams of a special type. Connectors have a metatype i have created. I success with this code :
Shared Sub HideConnector(ByVal Diagram As EA.Diagram, ByVal Connector As EA.Connector)
        Dim DiagramLink As EA.DiagramLink
        DiagramLink = Diagram.DiagramLinks.AddNew(Connector.ConnectorID, Connector.Type)
        DiagramLink.ConnectorID = Connector.ConnectorID
        DiagramLink.DiagramID = Diagram.DiagramID
        DiagramLink.IsHidden = True
        DiagramLink.Update()
        Diagram.DiagramLinks.Refresh()
    End Sub
But when i create an element with a quicklinker, the connector isn't hidden
Someone knows the difference between to create connectors with toolbox and to create connectors with quicklinkers ?
Thanks you
Bye
« Last Edit: June 02, 2008, 11:43:34 pm by damien »
damien
Re: Hide connectors
« Reply #1 on: June 03, 2008, 01:38:56 am »
Re
I apologize if i haven't explain very well my problem, I create a connector in a diagram A, i would know how can i hide this connector in all others diagram with an add-in. I try to define a diagramLink with isHidden = true, it works but when i create an element with quicklinkers, it doesn't work.
What is the good method to hide the connector to all diagrams except A ?
Thanks you
Bye
