Author Topic: Timers on sequence diagrams  (Read 10330 times)
ocroquette
« on: May 10, 2007, 02:14:09 am »
Hi
I want to show timers on my sequence diagrams, controlled by a certain lifeline.
If found the notation described on http://www.sequencediagrameditor.com/uml/sequence-diagram.htm very attractive.
How can I achieve this with EA?
Thanks for your help!
Olivier
Re: Timers on sequence diagrams
« Reply #1 on: May 10, 2007, 02:26:56 am »
Olivier,
EA allows a Receive Event to be displayed as an hourglass shape. See Time Event in the help index. I don't know if you can use this on a sequence diagram, or whether this would disrupt the resulting semantics.
Otherwise, you could define a stereotype with a simple shape script.
IMHO, If nobody comes up with a solution out of the box this is worth making a feature request to Sparx. Use the Support link at the top of the forum page, then click Feature Request from the left side menu.
ocroquette
« Reply #2 on: May 10, 2007, 05:14:13 am »
Thanks the information.
I will probably open a feature request.
In parallel, I am investigating the shape scripts.
I tried to set custom shapes for "message", "messageend" and "gate", which I thought could be the right base classes to do my timer's stuff, but I didn't have any luck.
I had already to use a workaround, because you can't select these types as base class anyway in the stereotypes editor.
I had to create an instance first, then open the properties,  and create the stereotype from there. Then it appears in the stereotype main editor, but setting a shape does not do anything on the sequence diagram  :(
« Reply #3 on: April 18, 2008, 02:19:00 pm »
Did this get reported as a bug/feature request.
It seems all sorts of stuff on sequence diagrams are immune from shape scripting; which is interesting as you CAN modify the appearance via some (but not all) of the appearance commands.
ocroquette
« Reply #4 on: April 18, 2008, 09:40:55 pm »
I don't think so.
Jan ´Bary´ Glas
  • Bary
« Reply #5 on: April 18, 2008, 10:18:46 pm »
It works with colors for metaclass MessageEndPoint (Diagram Gate, and partly for End Point - border only).
No experience with other.
HTH, Bary
Jan 'Bary' Glas
« Reply #6 on: April 22, 2008, 08:53:59 am »
I've been able to do something very close to the timer notation.
First, you'll need to disable Strict UML Syntax at Tools | Options | Diagram.
Then drag an action from the activity toolbox onto your diagram.
In the context menu select Advanced | Custom Properties.
Set the kind to AcceptEventTimer.
Drag a message from the action to the lifeline from the interaction toolbox. (This is what you'll need to disable strict UML for.)
