Author Topic: Version control - path to local copy?  (Read 3986 times)
Guillaume
    • www.umlchannel.com
« on: April 24, 2008, 01:49:37 am »
I'm using version control with Subversion/EA
I have an interface element in my model to which I'm linking word documents that are stored in the SVN repository.
I need all users to be able to launch this file and to do so, I need to specify their local working copy path.
This is set in the Version Control Settings > Local Working Path (e.g. C:\SVN\MyProject\)
The system environment I created with the uniqueID value points to the SVN url, not my working path
So, is there a way in EA to relate to this value stored in the version control settings?
I hope it makes sense...
Guillaume
peter.zrnko
Re: Version control - path to local copy?
« Reply #1 on: April 24, 2008, 06:50:30 pm »
Look at "Local Paths". It's for paths to generated files but it could work also for linked files.
Peter
Guillaume
« Reply #2 on: April 24, 2008, 08:24:45 pm »
Hi
I checked the local paths and the version had already created one but it doesn't work with the Files tab in my interface element for some reasons.
In Local Paths:
TEST = C:\Project\Test
When I select my local file in the Interface Files tab, the full path is:
C:\Project\Test\Docs\test document.doc
With this path, the file opens ok.
When I change the path to \%TEST%\Docs\test document.doc or %TEST%\Docs\test document.doc, it doesn't open the file
It eventually opens a folder but if I've specified more than 1 file using different folders, it only opens one of the folder so not the expected behaviour...
Any help will be appreciated.
thanks
Guillaume
