Author Topic: Problems with UML profiles from MDG Technology  (Read 4922 times)
brannstrom
« on: April 29, 2008, 06:25:19 pm »
Hi!
I'm using a MDG Technology that contains several profiles with stereotypes. When I create a new element with a stereotype from the MDG Technology it is created with the color set in the profile. But when I change the stereotype on an existing element then the color is not changed.
In the menu Settings->UML I can't see the stereotypes from the MDG Technology. I have to add the profiles from the profile packages that I used to create the Technology. Then I can see them under Settings->UML, but the stereotype doesn't have the right color. I have to manually set it, and then the stereotype is working as it should in the project.
Why isn't the stereotypes from the MDG Technology visible under Settings-UML. Am I doing something the wrong way?
/N
Re: Problems with UML profiles from MDG Technology
« Reply #1 on: April 29, 2008, 10:11:11 pm »
How are you loading the MDG Technology file?
brannstrom
« Reply #2 on: April 29, 2008, 10:22:35 pm »
I have placed it in the MDGTechnologies folder. I'm running build 828.
/N
« Reply #3 on: April 30, 2008, 02:47:22 am »
That's the appropriate approach all right. I was thinking you might have used the old way, which tended to 'forget' things.
I suggest you send a message to Sparx Support, asking whether this is the correct behavior. You'll find their address as a mailto: link on the Registered Users page near the top.
[EDIT: PS: Please let us know what light Sparx can shed on this.]
« Last Edit: April 30, 2008, 02:48:11 am by Midnight »
Dave_Bullet
« Reply #4 on: May 01, 2008, 07:53:35 am »
/N
As I understand, the stereotypes you create under Settings -> UML are stored separately from any profiles you import.  In other words, if you import a profile - it "hides" the stereotype and its behaviour under Settings -> UML.
I reecommend you avoid touching Settings -> UML and focus just on getting the MDG / profile to work.  Sorry I can't help you onthat, other than Settings -> UML will just confuse things.
I presume you are regenerating the MDG through the EA wizard?  If so - I think all you need to do is plonk it into the MDGTechnologies folder (as you are doing) then restart EA to reload the changes.
David.
brannstrom
« Reply #5 on: May 05, 2008, 08:35:09 pm »
/N
David.
The big problem is that the color is not right on "old" elements in the project with the same stereotype as in the MDG Tech. When I create new elements with the stereotype, then the color is right.
/N
« Reply #6 on: May 06, 2008, 08:52:01 am »
From memory the colors along with the tagged values specified by are profile are not updated from the profile automatically.
There is a synchronize tags and constraints function, (http://www.sparxsystems.com.au/EAUserGuide/index.html?synchronizetagsandconstrain.htm) but I don't think this effects the colors.  (And I don't think it can be used for an MDG technology that isn't loaded into the model.)
Have a look, then contact sparx support for advice.
