Author Topic: Multiuser: Database and/or Subversion?  (Read 4547 times)
MehrCurry
« on: May 06, 2008, 05:41:50 pm »
We are using EA with the model stored in a database. I am getting a little bit confused, what the recommended way of collaboration in a team is. As we use the central database, different users can access the model. But, as i understand, there is no versioning in this setup. So, to get versioning, i have to setup a subversion connection. But then, what benefits give me a central database?
I am a little bit confused. Can anyone give me a hint? :-/
Guido
Transition Technologies
Re: Multiuser: Database and/or Subversion?
« Reply #1 on: May 06, 2008, 05:59:07 pm »
Hi Guido,
This topic have been mentioned on this forum many times. One of the answers could be:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1208977826
« Last Edit: May 06, 2008, 06:00:09 pm by transition »
Authorized Reseller and Training Partner of Sparx Systems
www.ea.tt.com.pl
JohnDoe
  • EA rocks !
« Reply #2 on: May 06, 2008, 06:00:13 pm »
Hello Guido,
you can switch on "baselines" in EA, which means that you have versions in your database. You can compare versions in EA.
Just right click on a package and choose "package control -> manage baselines". There you can define baselines (i.e. versions) and visualize content changes between versions.
So, you should either use a database or a version system as your project repository. There is no need to have both. A database has more options (backup, sql access etc.), but must be managed by yourself. A version system is often available at public hosters such as sourceforge.
Best wishes
Bernd
« Reply #3 on: May 06, 2008, 11:35:39 pm »
Bernd,
I have to disagree, the database and the version control are two seperate features each with its own merits.
A central database has advantages like
- central point of access
- easy backup
- great collaboration: a modification can be viewed instantly by other users
Version Control offers
- manage different versions
- view differences between versions
- rollback
- branching
SwissSteve
« Reply #4 on: May 06, 2008, 11:47:20 pm »
I too am a little confused as to the best way to go on this issue.   I am keep to ditch the shared EAP file in favour of a DB and using Optomistic locking.
Where I have some difficulty is versioning.   Baselining sounds a good approach but am I limited to viewing a previous baseline only?  Ideally I want to be able to maintain different versions of a model.
I look forward to hear how others are approaching this issue.
MehrCurry
« Reply #5 on: May 06, 2008, 11:57:06 pm »
Hi Guido,
Of course, i thought this must be a faq. So i searched this forum for articles about subversion, but had no luck with it. Perhaps it may be possible the have such an information sticky.
Anyway, thanks for all answers.
Guido
« Reply #6 on: May 06, 2008, 11:57:22 pm »
« Reply #7 on: May 07, 2008, 12:00:53 am »
Hi Guido,
Guido
Ok I hope that we have helped you with this issue..
www.ea.tt.com.pl
