Author Topic: Free Format / Curved line  (Read 4880 times)
OzOracle
« on: May 04, 2008, 12:51:55 pm »
Is it possible to make a free format / curved line in an EA diagram ?
RoyC
  • Read The Help!
Re: Free Format / Curved line
« Reply #1 on: May 05, 2008, 08:25:55 am »
Best Regards, Roy
thomas.kilian
« Reply #2 on: May 05, 2008, 05:23:25 pm »
A bit EAUI: Create a Relation between elements. Now you can use bezier lines. Then change the type to association. Still you can use bezier though association basically does not allow that.
« Reply #3 on: May 06, 2008, 09:07:06 am »
You may find it easier to create an association and give it the tagged value _Bezier (case-sensitive) with the value "1".
thomas.kilian
« Reply #4 on: May 06, 2008, 07:11:18 pm »
Ah! I was wondering where that info was hidden :)
RoyC
  • Read The Help!
« Reply #5 on: May 07, 2008, 10:00:44 am »
No longer hidden. It will be in the Associate element description (UML Dictionary) in the next release of EA.
EDIT: Wider application, more detail, therefore we have added the information to the Connector Styles topic (in the previous link) instead. Changes will appear with the next product release.
« Last Edit: May 07, 2008, 12:31:07 pm by RoyC »
Best Regards, Roy
