Author Topic: Hyperlinks in Linked Document broken when it comes to html output  (Read 2619 times)
wuz
Hi all,
I want to describe elements using the linked document (strg+alt+d) mechanism. It is possible to create hyperlinks by drag and droping other elements into these documents. Unfortunately these links are appear to be broken in the html output.
Link address looks like ...html_report_test/linkdocs/$element://%7B50227CEE-5728-444f-A941-464E81AB7BE3%7D
Using EA 7.0.816
Thx and greetings
wuz
Re: Hyperlinks in Linked Document broken when it c
« Reply #1 on: May 07, 2008, 07:12:22 pm »
Hi all, seems that this issue is fixed in the 7.1 version. However when you click on a link (generated by drag on drop of an element from the project browser) you get to the element description and not to the linked document behind this element. This is an inconsistent behavior because normally you get directly to the linked document when you click on an element in the html output.
greetings
