Author Topic: Change Actor icon on diagrams  (Read 8656 times)
Dorian Workman
« on: May 06, 2008, 07:49:48 am »
Is there a way to change the icon used to display Actors on diagrams?  I have found that using a picture of a PC for system actors often helps business users understand this concept.  In NoMagic's MagicDraw, you are able to do this.
Is this possible in EA please?
Thanks.
<a href="http://www.linkedin.com/in/dorianworkman" ><img src="http://www.linkedin.com/img/webpromo/btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Dorian Workman
mrf
Re: Change Actor icon on diagrams
« Reply #1 on: May 06, 2008, 08:48:43 am »
Hi Dorian,
You can change either
- The image for an individual actor by right clicking on the actor and selecting Appearance | Select Alternate Image
- The image for a group of actors by creating a custom stereotype and defining a shapescript for it. All actors given the custom stereotype will be displayed using the shapescript.
For more information about shapescripts please refer to http://www.sparxsystems.com.au/EAUserGuide/index.html?shape_editor_2.htm
Best Regards,
Michael
Transition Technologies
« Reply #2 on: May 06, 2008, 05:33:29 pm »
Hi Dorian,
I would recommend to download and import the Image Library http://www.sparxsystems.com/resources/image_library.html
That will give you the images to substitute Actors, overwise you will have an empty list when clicking Appearance/Select Alternate Image.
Of course you can use your own images but you will have to adjust their sizes after all.
« Last Edit: May 06, 2008, 05:36:03 pm by transition »
Authorized Reseller and Training Partner of Sparx Systems
www.ea.tt.com.pl
Dorian Workman
« Reply #3 on: May 07, 2008, 04:53:51 am »
Thank you to both of you for replying so quickly, this is exactly what I was looking for.  Thanks!   :)
tnotland
« Reply #4 on: May 07, 2008, 05:31:57 pm »
On this note...
Is it possible to use the Image Library as a source of image for a custom stereotype? I don't want to change the appearance of the elements in the diagram, I want them to have a given appearance (image) every time I add a new element with a specific stereotype...
Brgds,
Tore
« Reply #5 on: May 07, 2008, 10:26:10 pm »
Yes, with the possible provision that the image be a metafile. You'll have to check that last bit for yourself.
AFAIR the Sparx image library provides the appropriate format.
[Settings | UML | Stereotypes tab (which is the default for the dialog).]
« Last Edit: May 07, 2008, 10:27:23 pm by Midnight »
