Author Topic: Need help: Red arrows above classifier  (Read 7651 times)
Steffen
« on: May 06, 2008, 12:38:48 am »
can someone explain to me, why there appeared small red arrows (v) above some of my classes in my UML diagramms?
They appeared after I added some attributes with whitespace characters in the attribute name (the target system allows that).
I couldn't find any view or documentation, that explains the red arrows and tells me, how to make them disappear.
They stayed although I removed the whitespace from attribute names.
I guess, they should mark some problem?
Does someone know, what's the problem and how to solve?
Thanks.
Re: Need help: Red arrows above classifier
« Reply #1 on: May 06, 2008, 01:29:34 am »
I don't know about a "v" but a small red triangle is a recurring question.
If that seems to fit the situation you have, it is a bookmark. Use shift-space to toggle this on and off. It is very easy to type a 'capital' space while editing an element, leaving you to wonder what happened.
[Having done that you might want to look it up in help - it is one of those things that you simply cannot find until you know what to call it - and see if the feature would be of any use to your users.]
HTH, David
Steffen
« Reply #2 on: May 06, 2008, 01:55:20 am »
this information helped a lot.
All red triangles disappeared and my customers will be happy  :)
Thanks.
« Reply #3 on: May 06, 2008, 10:05:58 pm »
I only helped you with the first.
Please tell us how to do the second!   ;)
Steffen
« Reply #4 on: May 07, 2008, 01:59:55 am »
As you said, I typed a 'capital' space because the attribute names had to be uppercase.
So, after I selected each marked class and hit shift-space again, the red triangles disappeared.
« Reply #5 on: May 07, 2008, 11:30:28 am »
Which is all fine and good.
But what I meant was: how did you manage to convert the customers to the happy state?
Jan ´Bary´ Glas
  • Bary
« Reply #6 on: May 07, 2008, 04:54:02 pm »
Jan 'Bary' Glas
Steffen
« Reply #7 on: May 07, 2008, 05:09:53 pm »
He doesn't know UML at all, and each symbol or figure he do not need to learn will make him at least a small bit happier...
that's it. :-?
« Last Edit: May 07, 2008, 05:10:35 pm by steffen.g »
« Reply #8 on: May 07, 2008, 10:24:49 pm »
You'll note that Jan's model never reaches an end state. That seems to be a common problem in this domain.
  :P
RoyC
  • Read The Help!
« Reply #9 on: May 08, 2008, 09:45:45 am »
Oh, I don't know.... an unending state of happiness as opposed to terminal happiness?
Best Regards, Roy
Jan ´Bary´ Glas
  • Bary
« Reply #10 on: May 09, 2008, 07:15:26 pm »
:-D
Jan 'Bary' Glas
