Author Topic: a little pbto generate sequnce diagrm for web app?  (Read 2833 times)
KGx
« on: May 20, 2008, 07:58:30 pm »
hi ,
i thank u for advices  i have a little problem!
i follow steps described in the help topic to attach the debugger to the tomcat server
i chechked the "let the service to interact with desktop " option
and i add the line related to the agent path  -agentpath:.........and before all of this i imported the source code to EA
the problem happen when i want to debug the apllication (wich is a little application one page and one servlet i created for test purposes) it says to me that no agent is loaded with tomcat server process but as i said i added th agent path pointing to the javaprofiler. : (
may be i had to change to another version of tomcat actually i use the 5.5
or may be i had to change some cofiguration varaible in tomcat
i dont know the cause of problem
thank you a lot  for help !!!
Re: a little pbto generate sequnce diagrm for web
« Reply #1 on: May 21, 2008, 08:44:26 am »
You really don't need to post the same thing to multiple boards.
I have removed the duplicate from the automation board.
