Author Topic: Problem accessing model via Java  (Read 3926 times)
SwissSteve
« on: May 21, 2008, 06:44:12 pm »
I have written a simple app to export my EA Model to HTML and it works fine when running under .NET.    Unfortunatly my customer requires this simple code in Java so I recompiled it in Java but it
does not work.
The call to OpenFile returns true but the call to GetProjectInterface()
returns NULL.
I tried to follow the instructions on using the lib i.e. I placed the SSJavaCOM.dll in the Windows, system32 directory and then added the eeapi jar to the Eclipse project.
Any suggestions would be apprecated.
repository = new org.sparx.Repository();
boolean status = repository.OpenFile(<eap file location>);
project = repository.GetProjectInterface();
project.RunHTMLReport("", "c:\\test", "PNG", "default", "htm");
SwissSteve
Re: Problem accessing model via Java
« Reply #1 on: May 21, 2008, 07:17:20 pm »
I wondered if I should first register the DLL so tried with
regsvr32 SSHavaCOM.dll
But go the error entry point DLLRegisterService not found.
 Anyone out the using Java to access EA?
« Reply #2 on: May 21, 2008, 08:31:27 pm »
Perhaps you should be using Regasm instead.
I'm not sure, so check the help files.
SwissSteve
« Reply #3 on: May 21, 2008, 10:20:36 pm »
I did already try this opion but it complains that it is not a valid .NET assembly.
Is there a more complete help page on using Java with EA?
TIA
SwissSteve
« Reply #4 on: May 21, 2008, 10:33:30 pm »
I wonder if we have the same issue as is posted here
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1207116302/2#2
We are also using version 828. Will upgrade version and post the results.
« Reply #5 on: May 22, 2008, 08:39:16 am »
If you are using build 828 then that will be causing the NULL result.  Upgrading to 829 should fix the problem.
SwissSteve
« Reply #6 on: May 22, 2008, 08:56:35 pm »
Downloaded the 829 files and all works fine, thanks to all for the advice
