Author Topic: Generate Package DDL error  (Read 2446 times)
pstein
« on: May 23, 2008, 08:28:16 am »
Assume I have a package defined with some "XSDcomplexTypes" in it.
I can succesfully create e.g. an XSD schema from it.
Now I want to create a DDL for a SQL database.
When I mark the package, right click and choose "Generate Package DDL" a dialog pops up. When I select now "Individual file for each table" and click "Generate" an error prompt appears:
Please select at least one table from the list!"
BUT: there is NO table it the list box below.
How can I otherwise select a table or generate DDL?
When I check "Single file" instead of "Individual file for each table"
what kind of file do I have to select in this case?
Peter
Re: Generate Package DDL error
« Reply #1 on: May 23, 2008, 09:12:17 am »
DDL generation and XSD generation happen from separate data.  So EA is quite right in not listing anything in the list.
I would recommend looking at transformations so that you can generate both models from a single source.  EA includes both DDL and XSD transformations that you can customize to your needs.
