Author Topic: Crash EA 7.0 on import of a profile  (Read 3983 times)
chadnash
« on: May 21, 2008, 05:06:30 pm »
It has happend twice now
I cna do it more if you want.
version 7.0.818 ms xp sp2
I am building a profile with some stereotypes that I am wanting to use
I may be doing this all wrong but here is how I can crash EA
I save the package I then savee the profile to an xml file I then imprt the profile via the resource window
sometimes the import false to overwrite the exisiting profile (this might be my fault somehow) and I get the profile in twice with the same name. when this happens ( it has happened twice) to clean up I delete both profiles using the resources window and try to import the profile again Kaboom EA crashes I have not yet succeeded in getting debig infomation.
Chad
chadnash
Re: Crash EA 7.0 on import of a profile
« Reply #1 on: May 21, 2008, 05:08:51 pm »
Extra info
wehn I rerun EA one profile is present in the model
I dont know if it was the one I was importing when the crash occured or one that I thought I deleted ( though the GUI did indicate a successfull delete when I did do the delete)
Chad
thomas.kilian
« Reply #2 on: May 21, 2008, 05:14:22 pm »
Not sure whether you used the Save as Profile option from the context according your docu. If you did, then you should report this as bug and send in the model.
Graham_Moir
« Reply #3 on: May 22, 2008, 12:39:41 am »
Is there any reason you're not on the latest build ?
chadnash
« Reply #4 on: May 22, 2008, 12:52:01 am »
slackness and extreme newbieness
I used the save that is available from a right mouse button on the package in the project browser - which I discovered via the doco
I will when I get a chance to upgrade to 7.1 and trie it out again
« Reply #5 on: May 22, 2008, 06:41:16 am »
FWIW...
I managed to crash EA 7.0 in a couple of different ways by using profiles. I was able to isolate two different patterns, both of which Sparx resolved in time for EA 7.1 production.
chadnash
« Reply #6 on: May 23, 2008, 12:45:53 pm »
Onto 7.1
Chad
