Author Topic: Can " be matched in a %REPLACE% call ?  (Read 2172 times)
Mark Stubley
« on: June 05, 2008, 02:58:36 am »
Is it possible to escape a double quote correctly so a quoted string can be matched in a replace call ? Seems that %qt% within a token already delimited by % causes issues.
Re: Can " be matched in a %REPLACE% call ?
« Reply #1 on: June 05, 2008, 08:27:54 am »
First, try qt without the quotes as one of the arguments to replace.  (You're right, % inside a function macro is bad syntax, the % symbols aren't used inside function macros or conditions.)
If that doesn't work, assign it to a variable and then use the variable.
