Author Topic: Can Sequence Diagram To Class Diagram?  or Sync?  (Read 3372 times)
garsia1983
« on: June 05, 2008, 01:23:13 pm »
I am learning iconix process. I want to learn about syncronize diagrams.
Can I Convert Sequence Diagram To Class Diagram in EA?
or Can I Syncronize Sequence Diagram with Class Diagram ?
Re: Can Sequence Diagram To Class Diagram?  or Syn
« Reply #1 on: June 05, 2008, 02:53:44 pm »
There isn't enough information in a sequence diagram to be able to automatically generate operations for a class diagram. For example, if a message says LoadElement(ID) what is the type of the ID parameter? is the parameter by reference or by value? are there any optional parameters? what is the type of the return value, if any? Too many questions.
What you need to do is to create each operation in the class element before you use it on a sequence diagram. To help you, the Message Properties dialog has an Operations button that takes you directly to the Operations dialog for the target lifeline's classifier element.
garsia1983
« Reply #2 on: June 05, 2008, 05:30:39 pm »
Thank you for your fast answer .
I got a good feeling for your company. thank you.
a.... and i have one more queation.
i am interesting of comportment of  reusing diagram.
can EA convert object to class?
it is uncomportable that
drawing object... and can't reuse..
and drawing class...
can you help me?
short reply is ok. thank you for spend time for me.
