Author Topic: How to link requirements to use case  (Read 3088 times)
ameetm
« on: June 06, 2008, 05:27:43 am »
Is there any feature in EA where the requirements can be linked in the use cases. In the requirements tab in use case there is a feature called Move external which allows to drop the requirement in the project browser, in the same way is it possible to do the reverse-- call a requirement from the project browser and drop it in the requirements tab in the use case
Re: How to link requirements to use case
« Reply #1 on: June 06, 2008, 08:44:08 am »
If you create a realization connector from the use case to the requirement.  The requirement will then be listed in the requirements tab for the use case.
ameetm
« Reply #2 on: June 06, 2008, 06:13:13 pm »
Thanks.... you saved me a lot of time  :)
Jan ´Bary´ Glas
  • Bary
« Reply #3 on: June 06, 2008, 10:57:28 pm »
OR drag a requirement from PRoject Browser onto an Use Case OR investigate on Relationship Matrix
Jan 'Bary' Glas
