Author Topic: SSJavaCOM: Unknown exception on comConstructor()  (Read 3322 times)
IvanY
« on: March 28, 2008, 02:28:09 am »
I'm trying to integrate EA with openArchitectureWare, via their "UML2ProfileExporter for EA".
Just running through the unit test model, I'm getting the following exception:
java.lang.Exception: Unknown exception thrown
      at org.sparx.Repository.comConstructor(Native Method)
      at org.sparx.Repository.<init>(Repository.java:150)
      at net.cmp4oaw.ea_com.repository.EA_Repository.<init>(EA_Repository.java:44)
Any pointers on what may be happening here? Since this is coming from the Repository constructor, and is just calling the SSJavaCOM comConstructor() function directly, I'm not sure that this is necessarily related to openArchitectureWare itself.
EA info: Corporate Edition, version 7.0.816
Thanks much,
Ivan
tom_guenter
Re: SSJavaCOM: Unknown exception on comConstructor
« Reply #1 on: June 18, 2008, 06:24:14 pm »
we had the same problem and were able to solve it. :) The description of our solution might be a help to you as well:
We used the automation interface the following way: On a Windows 2003 server, we installed an EA build 830 completely and also a Java application that connects to a EA repository using the automation interface. This tiny java application is triggered by the windows scheduler every night to perform backup operations. Everything worked fine, until one certain day, when the automation interface threw a Unknown Exception (build 828) and with build 830 an exception with the following message: Failed to construct object. Error code: 0x80080005
We found out, that this error only happens, if no user is logged in into the server at the time the job is running (via remote desktop).
In this case, no complete Windows profile is available and hence there is a security problem. The solution is to define the correct user for the DCOM-Component execution:
In the control panel to go "Management" and choose "component services". There, expand component services folder until you can choose the DCOM Service folder. In there, you have to look for an entry named EA.APP. In the context menu choose "Properties" and go to the "identity" tab. Enter the username and password of the user with which the job should be executed.
Tom
