Author Topic: Actor- Use Case associations at package level  (Read 3651 times)
mcaul
« on: June 19, 2008, 05:11:24 am »
Hi all, I'm enjoying EA, but have a question.
Is there a way to aggregate use cases and still show the associations at the higher level?
For example, I have an actor associated with a use case.  On the diagram, this shows a line between the two elements.  If I put the use case into a package, I would like to see the line appear on the diagram between the actor and the package.  It doesn't do this.
Enterprise Architect 7.1.830, under Windows XP.
Unregistered demonstration version.
mcaul
Re: Actor- Use Case associations at package level
« Reply #1 on: June 19, 2008, 07:22:08 am »
Answering my own question, partially ...
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1146938330
I still don't know if there is a way, besides using packages, to collect the use cases together and still see the actor relationships.
« Reply #2 on: June 19, 2008, 08:15:09 am »
Look into composite elements in the EA help. You can do this with use cases.
I know it is not quite what you describe, but you might find the end result acceptable.
HTH, David
mcaul
« Reply #3 on: June 20, 2008, 12:50:48 am »
<<Look into composite elements in the EA help. You can do this with use cases.
HTH, David>>
Thanks David for the tip.  I've started playing with the composite elements and I think they will be useful.
« Reply #4 on: June 20, 2008, 05:48:41 am »
Good stuff.
Search my recent posts - go back a month or two - for some other things you can do with 'child' diagrams.
mcaul
« Reply #5 on: June 21, 2008, 12:15:51 am »
Very helpful, thanks David, I found one here and will check it out.
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1211990136/1#1
