Author Topic: How to model C# generics?  (Read 2846 times)
togo
« on: June 28, 2008, 11:40:38 pm »
I am trying to model a simple class hierarchy using C# generics:
public interface Base<T> where T : MyClass2
   void something(T param);
public class MyClass : Base<MyClass2>
  void something(MyClass2 param) { ... }
I would like to draw a class diagram for this, but only managed to create the parametrized Base interface.
I can't seem to figure out how to:
    [*] Define the constraint on T so that the EA code generator creates the "where" clause;
    [*] Draw the generalization relationship with the annotation <<bind>> T -> MyClass2 (and make it work with the code generator).
    [/list]
    Am I missing something, or doesn't EA support generics?
    - Togo
    Re: How to model C# generics?
    « Reply #1 on: June 30, 2008, 04:23:06 am »
    EA seems to do this by using a parameterized class. Though the meaning is not strictly the same as it would be for C++ EA seems to make sense of it when the language is set to a .Net dialect.
    Try reverse engineering a simple piece of code and you'll see how EA does it. Once you've seen and played with it once you'll get the drift pretty fast.
    « Reply #2 on: June 30, 2008, 08:43:16 am »
    There are some limitations on the generics support, but as for your questions... The where clause is contained in a tagged value "genericConstraints
    " http://www.sparxsystems.com/EAUserGuide/index.html?csharp_conventions.htm
    Code engineering won't take into account a bind connector.  On the same dialog you made the base class parameterized you can make the child class instantiated and specify the arguments used.
    « Last Edit: June 30, 2008, 08:43:54 am by simonm »
