Author Topic: Show element list for diagrams  (Read 3735 times)
wuz
« on: June 24, 2008, 12:54:43 am »
Hi all,
Sorry i have another list question ;-). In the project browser there exists the possibility to list all elements with rightklick->Show element list. Within this list one can even select another toolbox or technology for the filter option. Unfortunately i didn't spot this possibility to list all diagrams? any suggestions?
cheers
PS: I think it is time that ea getas a query mechanisms to simple export the desired elements without loosing their tree structure to an .xls document or something like that
Re: Show element list for diagrams
« Reply #1 on: June 24, 2008, 08:47:02 am »
The CSV export can include tree structure, and any decent spreadsheet program should be able to import it.
What it doesn't do it include attributes etc.
« Last Edit: June 24, 2008, 08:48:27 am by simonm »
wuz
« Reply #2 on: July 08, 2008, 01:26:44 am »
Thx for your help, the cs output looked very promising but unfortunately i did not find any possibility to constraint the exported results only to the diagrams to get a list of their names!
Frank Horn
« Reply #3 on: July 08, 2008, 05:46:13 pm »
You could export to XMI 2.1 and then run a transformation like
<?xml version="1.0" encoding="utf-8"?>
<xsl:stylesheet  version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"  xmlns:uml = 'http://schema.omg.org/spec/UML/2.1'  xmlns:xmi = 'http://schema.omg.org/spec/XMI/2.1'>
      <xsl:output method="text" />
      <xsl:template match="/xmi:XMI" xmlns:xs="http://www.w3.org/2001/XMLSchema">
    <xsl:variable name="NewLine">
      <xsl:text>&#xD;&#xA;</xsl:text>
    </xsl:variable>
    <xsl:for-each select="descendant::diagram">
      <xsl:value-of select="properties/@name"/>
      <xsl:value-of select="$NewLine"/>
    </xsl:for-each>
      </xsl:template>
</xsl:stylesheet>
Dermot
« Reply #4 on: July 09, 2008, 11:02:19 am »
In version 7.1  - in the Advanced Search  - there is an option to create a query by diagram - try Ctrl-F - Advanced.  If you are keen you can also set up a SQL query.
