Author Topic: SQL2000 is Unsupported Lang.!  (Read 3201 times)
peace2008
« on: July 19, 2008, 10:17:15 pm »
I have sql2005 and EA 7.0.813 installed on my PC. I forward engineered from one of my DB schemes to a data model. Now I change a column in a table in sqlserver, then in EA press F7 to synchronize it with new changes. It says "SQL2000 is unsupported language...." :-?
Generally, I cannot reverse/forward engineer now.
Any idea is appreciate
« Last Edit: July 19, 2008, 10:24:18 pm by peace2008 »
Re: SQL2000 is Unsupported Lang.!
« Reply #1 on: July 20, 2008, 07:29:09 am »
AFAIK the F7 shortcut invokes the synchronize code function. This is meant for source code (i.e. programming language) only. EA makes a distinction between a programming language and SQL dialect. This means you're out of luck for now.
There is a limited ability to change tables, at least from EA to the database - read the documentation first, as there are both limitations and cautions involved. I don't know if you can update individual tables from the DBMS side without importing the entire model again. Note that importing again will lose any custom updates you've made; the elements in the model would be removed and replaced, not updated.
Perhaps this will change in future, but not likely until a future version of EA.
HTH, David
peace2008
« Reply #2 on: July 20, 2008, 02:02:03 pm »
Thanks David for the immediate reply  :)
So far as I remember I was forward engineering to SQL2005 by generating DDL script and I was reverse engineering by importing the changes. Regarding reverse engineering, I remember the same experience as your comments but about forward engineering, I remember that it was working  :-/ Thought none of them is working now
« Last Edit: July 20, 2008, 02:08:00 pm by peace2008 »
« Reply #3 on: July 21, 2008, 12:44:02 am »
Is it possible you are using an older model? Around the time that EA 7.0 came out I had some problems where different versions of MS SQL were involved.
At least one set of problems originated from older project files. Those from before EA 7 did not have SQL Server 2005 as an option, since EA did not then provide explicit support. This caused some problems when I attached newer schemas, since EA did not understand the language. [To be more accurate, the EA engine would have understood, but the DBMS languages did not include any references.]
I was able to get around this by exporting the DBMS Language reference data from a new (empty) project and importing it over the older data in my earlier project.
I don't know if this would apply in your case though.
