Author Topic: Display Function Parameters in Model  (Read 4528 times)
peace2008
« on: July 12, 2008, 05:49:26 pm »
When I add function to a class which has some input parameters, it only displays parameter type in model. How can I make it parameter name as well?
Takeshi K
    • Sparx Systems Japan
Re: Display Function Parameters in Model
« Reply #1 on: July 13, 2008, 05:58:07 am »
1. double-click the background of the target diagram
2. select the 'Features' tab
3. change the 'Show Parameter Detail' dropdown list
Hope this helps,
t-kouno
t-kouno
peace2008
« Reply #2 on: July 13, 2008, 01:39:18 pm »
Thanks a lot t-kouno :)
 That worked great
LastDragon
« Reply #3 on: August 07, 2008, 06:00:38 pm »
How to show parameter default value?
eg: +myFunction( str:string='myString' ):string
Takeshi K
« Reply #4 on: August 08, 2008, 05:28:12 pm »
As far as I know, EA has no option to show default values.
And as far as I know, UML specification does not define the operation notataion to show the default value. I think EA seems correct.
t-kouno
t-kouno
LastDragon
« Reply #5 on: August 08, 2008, 07:55:27 pm »
Really?
Please see: "UML Infrastructure Specification, v2.1.2", Chapter: "11.8.2 Operation" => Notation
<parameter-list> is a list of parameters of the operation in the following format:
    <parameter-list> ::= <parameter> [‘,’<parameter>]*
    <parameter> ::= [<direction>] <parameter-name> ‘:’ <type-expression>
                    [‘[‘<multiplicity>’]’] [‘=’ <default>] [‘{‘ <parm-property> [‘,’ <parm-property>]* ‘}’]
Takeshi K
« Reply #6 on: August 09, 2008, 10:30:03 pm »
You are right, I misread the specification document.
I'm sorry to bother you because of my mistake.
t-kouno
t-kouno
