Author Topic: Version 6.1 - Released (Build 791)  (Read 19251 times)
sparks
« on: May 31, 2006, 11:20:57 pm »
Corrected issue where RTF documents would fail to render correctly when Language Substitution was enabled
Resolved saving long object scenarios and correct scenario changes on Oracle.
Modified XMI importer to ensure that packages imported using "Strip GUIDs" are also stripped of Version Control settings.
DDL generation of stored procedures - corrected missing CREATE PROCEDURE statement when there was nothing in the Note field.
Corrected validation of association classes.
Corrected validation of CallOperationAction elements.
Resolved issue of EOF/BOF error message when generating rtf document.
Added default server connection name when creating a new connection.
Corrected issue with Japanese MySQL repository users.
Generate DDL - added index name to MySQL indexes.
Improved SCC version of "Get Latest" - now checks whether update has occurred before attempting import.
Modified SCC version of "File History" to prevent import of previous revision when package is currently checked-out.
Added version control command "Check In Branch".
Modified "Delete Package" function, to disallow deletion when selected package contains checked-out, version controlled child packages.
Generate DDL - resolved missing identity datatype for SQL Server.
Corrected order in which columns are added to constraints.
When generating HTML Report Polish characters now display correctly when using a JET 4.0 database.
Changed default Package, Element and Diagram ordering, in RTF reports, to Tree Order
Resolved missing FK links when importing tables where one table is named "Object".
Added handling of multiplicity to attribute inplace editor.
Modified display of abstract operations for C++ classes.
Added handling of more language constructs for Actionscript, C#, C++ (.Net), Delphi, Java, and VB.
Improved handling of indenting in Python parser.
Improved generation of VB.Net interfaces.
Resolved issue with generation of duplicate attributes from associations in C++ and Delphi.
« Last Edit: May 31, 2006, 11:23:10 pm by sparks »
