Author Topic: Create composite connector during transformation  (Read 2499 times)
mholyszko
« on: September 08, 2008, 12:03:28 pm »
How can I create a composite connector during models transformation?
I've tried the following:
Composition
  %TRANSFORM_REFERENCE("FormClass", classGUID)%
  Source
  Target
    %TRANSFORM_REFERENCE("ControllerClass", classGUID)%
but it resulted in showing an error that the 'Composition' element is invalid. Then I prepared a simple diagram with an aggregation and a composition between two elements and exported it to XMI file. There I saw that composite aggregation had the tag:
<UML:TaggedValue tag="subtype" value="Strong"/> and tried to apply that in the transformation template:
Aggregation
  Tag
    name = "subtype"
    value = "Strong"
but still no luck. A standard aggregation was created between two classes.
I couldn't find any information about that in the manual or previous topics on this forum, so I created a new topic, kindly asking for help.
mh
« Last Edit: September 08, 2008, 12:03:46 pm by mholyszko »
Re: Create composite connector during transformati
« Reply #1 on: September 09, 2008, 08:28:59 am »
You can ignore the tagged value from the XMI.  That doesn't correspond to a tagged value in EA.
The actual way to create one can be found by transforming an existing composition connector.
Aggregation
  Source
  Target
    aggregation="2"
mholyszko
« Reply #2 on: September 09, 2008, 09:02:33 am »
That worked. Thank you very much for your help. I definitely wouldn't solve this problem by myself.
mh
« Last Edit: September 09, 2008, 09:03:35 am by mholyszko »
