Author Topic: Only one instance of an element in a diagram  (Read 2295 times)
David Koudela
« on: September 09, 2008, 10:14:39 pm »
Hello all,
During pasting of second element's instance into a deployment diagram I got following error:
This diagram already contains an instance of the element you are trying to paste.
Currently, only one instance is supported, so you cannot paste the element here.
Unfortunately, I have a deployment where same component instances occur in different nodes, but all nodes are currently inside the same deployment diagram.
Is there any workaround how to manage this? I don’t want to create several UML components referring to the same physical component.
David.
