Author Topic: Attribute changes cannot be saved instantly  (Read 2871 times)
Andris
« on: September 14, 2008, 12:29:32 am »
In a class diagram I created an attribute to a class then modified it by creating a property of it. After that I pressed Save in the attribute dialog and I got this window-cavalcade:
http://datastore.uw.hu/ea/ea.swf
Of course after clickin so many Yes, the modification isn't saved and on closing the dialog I was asked whether to save the modification that were made to the attributes. I intend to create 20-30 more classes and if it requires 10 clicks per one attribute to save, I really get mad. So can I somehow override this overprotective way and enable autosave of modifications?
« Last Edit: September 14, 2008, 12:33:16 am by nologin »
Re: Attribute changes cannot be saved instantly
« Reply #1 on: September 15, 2008, 08:20:45 am »
It looks like a bug.
I'd recommend upgrading to the latest build if you're not on it already and sending a bug report to sparx systems if the problem persists on the latest build.
