Author Topic: Floating License in a File Server  (Read 4041 times)
Mario romero
« on: October 11, 2008, 06:43:16 am »
Hi, I have to install a floting license EA in my company... I follow the steps to generate the "sskeys.dat" file in a Windows network file-system (it runs on a storage solution RAID 5) from my worstation. So far so good, I register the floating license in 3 PC's but I got a "Key file has been moved" error in other ones.
Have you ever got this scenario? I read in the troubleshooting section that  working with a Raid solution can be dificult, but I don't have other Non-Raid server to try.
Thanks!
Mario Romero
www.epidataconsulting.com
Dave_Bullet
Re: Floating License in a File Server
« Reply #1 on: October 14, 2008, 08:28:39 am »
The actual disk implementation (RAID or not) should not make a difference.
You either refer to the path of the sskeys.dat file from a client using either:
UNC path - ie. \\server\path\sskeys.dat (where server is a fully qualified name if in another domain - like server.domain or an IP address, or just the server name if in the same domain
or
Drive letter - ie. x:\path\sskeys.dat
All users must have read AND write access to the folder and sskeys.dat file (since they need to write to the file updating it when they acquire a license).
Cheers,
DAvid.
« Reply #2 on: October 14, 2008, 09:24:43 am »
I'm not sure what troubleshooting section is being referred to, but it probably has a reason for saying that a RAID solution can be tricky.  From what I believe, a keystore is bound to a hard disk.  If I'm correct, I can easily see why a RAID could cause problems.
Mario romero
« Reply #3 on: October 15, 2008, 12:22:56 am »
Hi! This is the troubleshooting section referred: http://www.sparxsystems.com/uml_tool_guide/license_management/keystore_troubleshooting.html
Dave_Bullet
« Reply #4 on: October 15, 2008, 09:25:42 am »
The helpfile alludes to the keystore using the hard drive ID when creating the keystore file.  I don't know what API is used, but maybe if EA is checking / regenerating this - it is getting a different ID for each disk in the RAID.
We operate a fully 2 fledged SANs (terrabytes of data) with RAID1+0 over a geographically dispersed WAN and don't have a problem.
This is a tricky one....
Cheers,
David.
