Author Topic: Search elements filtered on ClassifierId  (Read 3305 times)
ashwinib
« on: July 09, 2008, 09:39:18 pm »
Is there any method with which i will get the collection of elements where classifierId is some ElementId (like ClassifierId = 62) from whole repository.
Or Is there any method available in API with which I will get list of all the elements (in Packages or sub packages...).
List<Element> having all the elements from repository.
Is any of above method available??
Thanks & Regards,
Ashwini
Re: Search elements filtered on ClassifierId
« Reply #1 on: July 09, 2008, 10:17:03 pm »
Hi Ashwini,
You can run a prepared search - I'll leave you to look up searches - VIA the repository.RunModelSearch method.
There is also a Repository.SQLQuery method which lets you run an SQL query directly against the model database.
You'll have to fiddle around a bit to see how the results are returned, but it does make sense. [Particularly so if you are using generics...]
