Author Topic: Target Language for Resource  (Read 2880 times)
George Meng
« on: October 16, 2008, 02:14:44 am »
Hello all,
When I build a class model, I can drag a UML pattern from Resource tab, that is great feature.
However, that leave the language with "<none>". I have to manually change it to "ActionScript" or "VB", otherwise, I will get C++.
Is there a way I change change the default language of UML Pattern to "ActionScript"?
Thanks a lot!
George :o
Re: Target Language for Resource
« Reply #1 on: October 17, 2008, 09:13:48 am »
There are three versions of the patterns available.  A Java, C# and language independent.
If you use a language independent pattern, and try to generate from it directly, the default language for your model will be selected in your dialog.  You could either change it at that point, or change your model default.
