Author Topic: red dot/triangle  (Read 4176 times)
webrod
red dot/triangle
« on: October 17, 2008, 05:46:05 pm »
I have something red, on the bottom right of the package which is controlled by SVN.
It looks like a triangle. I'm not speacking about the red triangle when there is a bookmark. I'm not speaking about the red dot which appears on the left when SVN does not find the XMI file.
Do you know what does it means?
thanks for your help  :)
rod
Takeshi K
    • Sparx Systems Japan
Re: red dot/triangle
« Reply #1 on: October 18, 2008, 07:33:10 am »
The red dot means that the package is the 'Controlled Package'.
If the version controll does not work correctly, the version-controlled
packages are shown as controlled packages.
Usually if you fix a problem of version control, the package will work as a version-controlled package again. Or, if you do not want to use the package as version-controlled package any more, uncheck the 'Control Package' checkbox in the Package Control Options dialog.
Hope this helps.
t-kouno
« Reply #2 on: October 20, 2008, 09:10:34 am »
This page in the help file shows the various icons and their meanings. It sounds to me like you are talking about a namespace root...
Takeshi K
« Reply #3 on: October 20, 2008, 10:15:44 am »
KP's comment is correct.
I overlook the 'bottom' word. My description is for 'top' red dot.
t-kouno
webrod
« Reply #4 on: October 22, 2008, 02:10:58 am »
thanks you for your answer KP it solved my problem
Rod
