Author Topic: Boundary with a label  (Read 2532 times)
Andi
« on: October 31, 2008, 09:41:11 pm »
Hi
In literatur about EA I can find diagrams with boudaries which have a label in the left top corner. I would like to do this in the same way, but I did not find how to do this. Can somebody give me a hint?
Andi
Re: Boundary with a label
« Reply #1 on: October 31, 2008, 11:17:50 pm »
Sure Andi,
Open the Tools | Options | Diagram dialog. You will see two sections that will determine diagram borders and labels. Across the center of the dialog you'll see a section called Use Opaque Diagram Labels. It has independent settings for different output targets.
At the bottom right you will see a section called Diagram Frames. Once again you have independent choices based on the intended target.
After you set these options EA will remember them for future sessions (until you change them again of course).
HTH, David
