Author Topic: RTF Documentation - Package Element vs Elements  (Read 2655 times)
Jeff Cantrill
« on: November 04, 2008, 05:44:23 am »
Is there any documentation about the difference between a 'Package Element' and an 'Element' when generating RTF Documentation?    For that matter, is there any documentation regarding the elements you can pull into a template?  Some of them can obviously be mapped to a tab on the properties pane or other assorted field, but, for example, what does it mean to choose a 'model document'?  Is this just another 'element' or 'package element'?
Oliver F.
    • Karl Storz homepage
Re: RTF Documentation - Package Element vs Element
« Reply #1 on: November 04, 2008, 07:23:43 pm »
The "model element" is the root of the model and contains basic information about the model itself (which is not much- tasks, issues, etc.).
A package (at least in terms of RTF documents) is not an element but treated more like a chapter to separate items.
For a brief information about RTF documentation you can read the whitepaper from Sparx:
http://www.sparxsystems.com/downloads/whitepapers/Working_with_the_RTF_generator.pdf
Oliver
Jeff Cantrill
« Reply #2 on: November 05, 2008, 01:05:17 am »
Oliver,
I don't mean to sound unappreciative of your response, but it was about as valuable as the whitepaper you directed me to; the one that is also referenced in the help documentation.  The documentation regarding the creation of RTF's is very weak.  It is not obvious at what I will get unless I spend hours generating samples.  Even though the whitepaper is of use for a number of topics, I was hoping that something more existed to further explain EXACTLY what each element does when one clickes the check box.
