Author Topic: How to set minimum size for class in class diagram  (Read 3171 times)
Farrukh Najmi
« on: November 05, 2008, 04:03:33 am »
I have turned of visibility for all attributes and element in my diagram.
When I drag and drop a class the box is too big. How can I make the default size be as small as possible without manually resizing for each class?
JPHespanha
  • et pluribus unum
Re: How to set minimum size for class in class dia
« Reply #1 on: November 05, 2008, 05:13:18 am »
Have you tried:
1. select all classes and from Properties in the context menu, select Feature Visibility and Wrap features;
2. From the main menu, select Element -> appearance -> Autosize or simply hit the Alt+Z key.
Joao Paulo Hespanha
OTB Research Institute
Technical University Delft
